# 从Kafka读取数据写入到RDS
![](https://support.huaweicloud.com/devg-dli/public_sys-resources/notice_3.0-zh-cn.png)
本指导仅适用于Flink 1.12版本。
#### 场景描述
该场景为根据商品的实时点击量，获取每小时内点击量最高的3个商品及其相关信息。商品的实时点击量数据为输入源发送到Kafka中，再将Kafka数据的分析结果输出到RDS中。
例如，输入如下样例数据：
{"user_id":"0001", "user_name":"Alice", "event_time":"2021-03-24 08:01:00", "product_id":"0002", "product_name":"name1"}
{"user_id":"0002", "user_name":"Bob", "event_time":"2021-03-24 08:02:00", "product_id":"0002", "product_name":"name1"}
{"user_id":"0002", "user_name":"Bob", "event_time":"2021-03-24 08:06:00", "product_id":"0004", "product_name":"name2"}
{"user_id":"0001", "user_name":"Alice", "event_time":"2021-03-24 08:10:00", "product_id":"0003", "product_name":"name3"}
{"user_id":"0003", "user_name":"Cindy", "event_time":"2021-03-24 08:15:00", "product_id":"0005", "product_name":"name4"}
{"user_id":"0003", "user_name":"Cindy", "event_time":"2021-03-24 08:16:00", "product_id":"0005", "product_name":"name4"}
{"user_id":"0001", "user_name":"Alice", "event_time":"2021-03-24 08:56:00", "product_id":"0004", "product_name":"name2"}
{"user_id":"0001", "user_name":"Alice", "event_time":"2021-03-24 09:05:00", "product_id":"0005", "product_name":"name4"}
{"user_id":"0001", "user_name":"Alice", "event_time":"2021-03-24 09:10:00", "product_id":"0006", "product_name":"name5"}
{"user_id":"0002", "user_name":"Bob", "event_time":"2021-03-24 09:13:00", "product_id":"0006", "product_name":"name5"}
预期输出：
2021-03-24 08:00:00 - 2021-03-24 08:59:59,0002,name1,2
2021-03-24 08:00:00 - 2021-03-24 08:59:59,0004,name2,2
2021-03-24 08:00:00 - 2021-03-24 08:59:59,0005,name4,2
2021-03-24 09:00:00 - 2021-03-24 09:59:59,0006,name5,2
2021-03-24 09:00:00 - 2021-03-24 09:59:59,0005,name4,1
1. 已创建DMS Kafka实例。 具体步骤可参考：[DMS Kafka入门指引](https://support.huaweicloud.com/qs-kafka/kafka-qs-0409001.html)。
   ![](https://support.huaweicloud.com/devg-dli/public_sys-resources/caution_3.0-zh-cn.png)
   创建DMS Kafka实例时，**不能开启Kafka SASL_SSL**。
2. 已创建RDS for MySQL实例。 本示例创建的RDS for MySQL数据库版本选择为：8.0。
   具体步骤可参考：[购买RDS for MySQL实例](https://support.huaweicloud.com/usermanual-rds-mysql/rds_10_0028.html)。
#### 整体作业开发流程
整体作业开发流程参考[图1]。
图1作业开发流程
![](https://support.huaweicloud.com/devg-dli/zh-cn_image_0000002430386960.png "点击放大")
[步骤1：创建弹性资源池并添加队列]：创建DLI作业运行的队列。
[步骤2：创建Kafka的Topic]：创建Kafka生产消费数据的Topic。
[步骤3：创建RDS数据库和表]：创建RDS for MySQL数据库和表信息。
[步骤4：创建增强型跨源连接]：DLI上创建连接Kafka和RDS的跨源连接，打通网络。
[步骤5：运行作业]：DLI上创建和运行Flink OpenSource作业。
[步骤6：发送数据和查询结果]：Kafka上发送流数据，在RDS上查看运行结果。
 #### 步骤1：创建弹性资源池并添加队列
新建队列的网段不能和DMS Kafka、RDS for MySQL实例的子网网段有重合，否则后续创建跨源连接会失败。
1. 登录DLI管理控制台。
2. 在左侧导航栏单击"资源管理 \> 弹性资源池"，可进入弹性资源池管理页面。
3. 在弹性资源池管理界面，单击界面右上角的"购买弹性资源池"。
4. 在"购买弹性资源池"界面，填写具体的弹性资源池参数。
   本例在华东-上海二区域购买按需计费的弹性资源池。相关参数说明如[表1]所示。
    表1参数说明
   | 参数名称 | 参数说明                                                             | 配置样例              |
   | 计费模式 | 选择弹性资源池计费模式。                                                     | 按需计费              |
   | 区域   | 选择弹性资源池所在区域。                                                     | 华东-上海二            |
   | 项目   | 每个区域默认对应一个项目，由系统预置。                                              | 系统默认项目            |
   | 名称   | 弹性资源池名称。                                                         | dli_resource_pool |
   | 规格   | 选择弹性资源池规格。                                                       | 标准版               |
   | CU范围 | 弹性资源池最大最小CU范围。                                                   | 64-64             |
   | 网段   | 规划弹性资源池所属的网段。如需使用DLI增强型跨源，弹性资源池网段与数据源网段不能重合。**弹性资源池网段设置后不支持更改**。 | 172.16.0.0/19     |
   | 企业项目 | 选择对应的企业项目。                                                       | default           |
5. 参数填写完成后，单击"立即购买"，在界面上确认当前配置是否正确。
6. 单击"提交"完成弹性资源池的创建。
7. 在弹性资源池的列表页，选择要操作的弹性资源池，单击操作列的"添加队列"。
8. 配置队列的基础配置，具体参数信息如下。
   表2弹性资源池添加队列基础配置
   | 名称   | 弹性资源池添加的队列名称。        | dli_queue_01        |
   | 类型   | 选择创建的队列类型。 - 执行SQL作业请选择SQL队列。  - 执行Flink或Spark作业请选择通用队列。   | SQL作业场景请选择"SQL队列"。 其他场景请选择"通用队列"。 |
   | 执行引擎 | SQL队列可以选择队列引擎为Spark。        | Spark        |
9. 单击"下一步"，配置队列的扩缩容策略。 单击"新增"，可以添加不同优先级、时间段、"最小CU"和"最大CU"扩缩容策略。
   本例配置的扩缩容策略如[图2]所示。
   图2添加队列时配置扩缩容策略
   ![](https://support.huaweicloud.com/devg-dli/zh-cn_image_0000002000460541.png "点击放大")
   表3扩缩容策略参数说明
   | 优先级  | 当前弹性资源池中的优先级数字越大表示优先级越高。本例设置一条扩缩容策略，默认优先级为1。                                                      | 1     |
   | 时间段  | 首条扩缩容策略是默认策略，不能删除和修改时间段配置。 即设置00-24点的扩缩容策略。 | 00-24 |
   | 最小CU | 设置扩缩容策略支持的最小CU数。        | 16    |
   | 最大CU | 当前扩缩容策略支持的最大CU数。        | 64    |
10. 单击"确定"完成添加队列配置。
 #### 步骤2：创建Kafka的Topic
1. 登录Kafka管理控制台，选择"Kafka专享版"，单击对应的Kafka实例名称，进入到Kafka实例的基本信息页面。
2. 单击"Topic管理 \> 创建Topic"，创建一个Topic。Topic配置参数如下：
   - Topic名称。本示例输入为：testkafkatopic。
   - 分区数：1。
   - 副本数：1。
   其他参数保持默认即可。
 #### 步骤3：创建RDS数据库和表
1. 登录RDS管理控制台，在"实例管理"界面，选择已创建的RDS for MySQL实例，选择操作列的"更多 \> 登录"，进入数据管理服务实例登录界面。
2. 输入实例登录的用户名和密码。单击"登录"，即可进入RDS for MySQL数据库并进行管理。
3. 在数据库实例界面，单击"新建数据库"，数据库名定义为：testrdsdb，字符集保持默认即可。
4. 在已创建的数据库的操作列，单击"SQL查询"，输入以下创建表语句，创建RDS for MySQL表。
   CREATE TABLE clicktop (
   `range_time` VARCHAR(64) NOT NULL,
   `product_id` VARCHAR(32) NOT NULL,
   `product_name` VARCHAR(32),
   `event_count` VARCHAR(32),
   PRIMARY KEY (`range_time`,`product_id`)
   )ENGINE = InnoDB
   DEFAULT CHARACTER SET = utf8mb4;
 #### 步骤4：创建增强型跨源连接
- **创建DLI连接Kafka的增强型跨源连接**
  1. 在Kafka管理控制台，选择"Kafka专享版"，单击对应的Kafka名称，进入到Kafka的基本信息页面。
  2. 在"连接信息"中获取该Kafka的"内网连接地址"，在"基本信息"的"网络"中获取该实例的"虚拟私有云"和"子网"信息，方便后续操作步骤使用。
  3. 单击"网络"中的安全组名称，在"入方向规则"中添加放通队列网段的规则。例如，本示例队列网段为"10.0.0.0/16"，则规则添加为：优先级选择：1，策略选择：允许，协议选择：TCP，端口值不填，类型：IPv4，源地址为：10.0.0.0/16，单击"确定"完成安全组规则添加。
  4. 登录DLI管理控制台，在左侧导航栏单击"跨源管理"，在跨源管理界面，单击"增强型跨源"，单击"创建"。
  5. 在增强型跨源创建界面，配置具体的跨源连接参数。具体参考如下。
     - 连接名称：设置具体的增强型跨源名称。本示例输入为：dli_kafka。
     - 弹性资源池：选择[步骤1：创建弹性资源池并添加队列]中已经创建的弹性资源池名称。（未添加至资源池的队列，请直接选择队列名称。）
     - 虚拟私有云：选择Kafka的虚拟私有云。
     - 子网：选择Kafka的子网。
     - 其他参数可以根据需要选择配置。
     参数配置完成后，单击"确定"完成增强型跨源配置。单击创建的跨源连接名称，查看跨源连接的连接状态，等待连接状态为"已激活"后可以进行后续步骤。
  6. 单击"队列管理"，选择操作的队列，本示例为[步骤1：创建弹性资源池并添加队列]中创建的队列，在操作列，单击"更多 \> 测试地址连通性"。
  7. 在"测试连通性"界面，根据[2]中获取的Kafka连接信息，地址栏输入"Kafka内网地址:Kafka数据库端口"，单击"测试"测试DLI到Kafka网络是否可达。
- **创建DLI连接RDS的增强型跨源连接**
  1. 在RDS管理控制台，选择"实例管理"，单击对应的RDS实例名称，进入到RDS的基本信息页面。
  2. 在"基本信息"的"连接信息"中获取该实例的"内网地址"、"数据库端口"、"虚拟私有云"和"子网"信息，方便后续操作步骤使用。
  3. 单击"连接信息"中的安全组名称，在"入方向规则"中添加放通队列网段的规则。例如，本示例队列网段为"10.0.0.0/16"，则规则添加为：优先级选择：1，策略选择：允许，协议选择：TCP，端口值不填，类型：IPv4，源地址为：10.0.0.0/16，单击"确定"完成安全组规则添加。
  4. Kafka和RDS实例属于同一VPC和子网下？
     1. 是，执行[7]。Kafka和RDS实例在同一VPC和子网，不用再重复创建增强型跨源连接。
     2. 否，执行[5]。Kafka和RDS实例分别在两个VPC和子网下，则要分别创建增强型跨源连接打通网络。
  5. 登录DLI管理控制台，在左侧导航栏单击"跨源管理"，在跨源管理界面，单击"增强型跨源"，单击"创建"。
  6. 在增强型跨源创建界面，配置具体的跨源连接参数。具体参考如下。
     - 连接名称：设置具体的增强型跨源名称。本示例输入为：dli_rds。
     - 弹性资源池：选择[步骤1：创建弹性资源池并添加队列]中已经创建的队列名称。（未添加至资源池的队列，请直接选择队列名称。）
     - 虚拟私有云：选择RDS的虚拟私有云。
     - 子网：选择RDS的子网。
     - 其他参数可以根据需要选择配置。
     参数配置完成后，单击"确定"完成增强型跨源配置。单击创建的跨源连接名称，查看跨源连接的连接状态，等待连接状态为："已激活"后可以进行后续步骤。
  7. 单击"队列管理"，选择操作的队列，本示例为[步骤1：创建弹性资源池并添加队列]中创建的队列，在操作列，单击"更多 \> 测试地址连通性"。
  8. 在"测试连通性"界面，根据[2]中获取的RDS连接信息，地址栏输入"RDS内网地址:RDS数据库端口"，单击"测试"测试DLI到RDS网络是否可达。
 #### 步骤5：运行作业
1. 在DLI管理控制台，单击"作业管理 \> Flink作业"，在Flink作业管理界面，单击"创建作业"。
2. 在创建作业界面，作业类型选择"Flink OpenSource SQL"，名称填写为：FlinkKafkaRds。单击"确定"，跳转到Flink作业编辑界面。
3. 在Flink OpenSource SQL作业编辑界面，配置如下参数，其他参数默认即可。
   - 所属队列：选择[步骤1：创建弹性资源池并添加队列]中创建的队列。
   - Flink版本：选择1.12。
   - 保存作业日志：勾选。
   - OBS桶：选择保存作业日志的OBS桶，根据提示进行OBS桶权限授权。
   - 开启Checkpoint：勾选。
   - Flink作业编辑框中输入具体的作业SQL，本示例作业参考如下。SQL中加粗的参数需要根据实际情况修改。
     ![](https://support.huaweicloud.com/devg-dli/public_sys-resources/note_3.0-zh-cn.png)
     本示例使用的Flink版本为1.12，故Flink OpenSource SQL语法也是1.12。本示例数据源是Kafka，写入结果数据到RDS。
     请参考[Flink OpenSource SQL 1.12创建Kafka源表](https://support.huaweicloud.com/sqlref-flink-dli/dli_08_0386.html)、[Flink OpenSource SQL 1.12创建JDBC结果表](https://support.huaweicloud.com/sqlref-flink-dli/dli_08_0397.html)（RDS连接）。
     create table click_product(
         user_id string, --点击用户的id
         user_name string, --用户名称
         event_time string, --点击时间
         product_id string, --商品id
         product_name string --商品名称
     ) with (
         "connector" = "kafka",
         "properties.bootstrap.servers" = "10.128.0.120:9092,10.128.0.89:9092,10.128.0.83:9092",--替换为kafka的内网连接地址和端口
         "properties.group.id" = "click",
         "topic" = "testkafkatopic",--创建的Kafka Topic名称
         "format" = "json",
         "scan.startup.mode" = "latest-offset"
     --结果表
     create table top_product (
         range_time string, --计算的时间范围
         product_name string, --商品名称
         event_count bigint, --点击次数
         primary key (range_time, product_id) not enforced
     ) with (
         "connector" = "jdbc",
         "url" = "jdbc:mysql://192.168.12.148:3306/testrdsdb",--testrdsdb为创建的RDS的数据库名，IP和端口替换为RDS for MySQL的实例IP和端口
         "table-name" = "clicktop",
         "pwd_auth_name"="xxxxx", --DLI侧创建的Password类型的跨源认证名称。使用跨源认证则无需在作业中配置账号和密码。
         "sink.buffer-flush.max-rows" = "1000",
         "sink.buffer-flush.interval" = "1s"
     create view current_event_view
     as
         select product_id, product_name, count(1) as click_count, concat(substring(event_time, 1, 13), ":00:00") as min_event_time, concat(substring(event_time, 1, 13), ":59:59") as max_event_time
         from click_product group by substring (event_time, 1, 13), product_id, product_name;
     insert into top_product
         select
             concat(min_event_time, " - ", max_event_time) as range_time,
             product_id,
             product_name,
             click_count
         from (
             select *,
             row_number() over (partition by min_event_time order by click_count desc) as row_num
             from current_event_view
         where row_num <= 3
4. 单击"语义校验"确保SQL语义校验成功。单击"保存"，保存作业。单击"启动"，启动作业，确认作业参数信息，单击"立即启动"开始执行作业。等待作业运行状态变为"运行中"。
 #### 步骤6：发送数据和查询结果
1. 使用Kafka客户端向[步骤2：创建Kafka的Topic]中的Topic发送数据，模拟实时数据流。
   Kafka生产和发送数据的方法请参考：[DMS - 连接实例生产消费信息](https://support.huaweicloud.com/usermanual-kafka/kafka-ug-180604020.html)。
   发送样例数据如下：
2. 登录RDS控制台，单击RDS数据库实例，单击创建的数据库名，如"testrdsdb"，在创建的表"clicktop"所在行的"操作"列，单击"SQL查询"，输入以下查询语句。
   select * from `clicktop`;
3. 在"SQL查询"界面，单击"执行SQL"，查看RDS表数据已写入成功。
   图3RDS表数据
   ![](https://support.huaweicloud.com/devg-dli/zh-cn_image_0000002463945561.png "点击放大")
