# Pod接口ExtendPathMode: PodUID如何与社区client-go兼容？
#### 使用场景
社区Pod结构体中没有ExtendPathMode，用户使用client-go调用创建pod或deployment的API接口时，创建的pod中没有ExtendPathMode。为了与社区的client-go兼容，CCE提供了如下解决方案。
#### 解决方案
![](https://support.huaweicloud.com/cce_faq/public_sys-resources/notice_3.0-zh-cn.png)
- 创建pod时，在pod的annotation中需增加**kubernetes.io/extend-path-mode。**
- 创建deployment时，需要在template中的annotation增加**kubernetes.io/extend-path-mode**。
如下为创建pod的yaml示例，在annotation中添加**kubernetes.io/extend-path-mode** 关键字后，完全匹配到containername，name，mountpath三个字段，则会在volumeMount中增加对应的**extendpathmode**：
apiVersion: v1
kind: Pod
  generateName: test-8b59d5884-
  namespace: default
  selfLink: /api/v1/namespaces/default/pods/test-8b59d5884-96vdz
  labels:
    app: test
    pod-template-hash: 8b59d5884
  annotations:
    kubernetes.io/extend-path-mode: '[{"containername":"container-0","name":"vol-156738843032165499","mountpath":"/tmp","extendpathmode":"PodUID"}]'
    metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]'
  ownerReferences:
    - apiVersion: apps/v1
      kind: ReplicaSet
      uid: 2633020b-cd23-11e9-8f83-fa163e592534
      controller: true
      blockOwnerDeletion: true
  volumes:
    - name: vol-156738843032165499
      hostPath:
        path: /tmp
        type: ''
    - name: default-token-4s959
      secret:
        secretName: default-token-4s959
        defaultMode: 420
  containers:
    - name: container-0
      image: 'nginx:latest'
      env:
        - name: PAAS_APP_NAME
          value: test
        - name: PAAS_NAMESPACE
          value: default
        - name: PAAS_PROJECT_ID
          value: b6315dd3d0ff4be5b31a963256794989
      resources:
        limits:
          cpu: 250m
          memory: 512Mi
        requests:
          cpu: 250m
          memory: 512Mi
      volumeMounts:
          mountPath: /tmp
          extendPathMode: PodUID
          readOnly: true
          mountPath: /var/run/secrets/kubernetes.io/serviceaccount
      terminationMessagePath: /dev/termination-log
      terminationMessagePolicy: File
      imagePullPolicy: Always
  restartPolicy: Always
  terminationGracePeriodSeconds: 30
  dnsPolicy: ClusterFirst
  serviceAccountName: default
  serviceAccount: default
  nodeName: 192.168.0.24
  securityContext: {}
  imagePullSecrets:
    - name: default-secret
  affinity: {}
  schedulerName: default-scheduler
  tolerations:
    - key: node.kubernetes.io/not-ready
      operator: Exists
      effect: NoExecute
      tolerationSeconds: 300
    - key: node.kubernetes.io/unreachable
      operator: Exists
      effect: NoExecute
  priority: 0
  dnsConfig:
    options:
      - name: timeout
        value: ''
      - name: ndots
        value: '5'
      - name: single-request-reopen
  enableServiceLinks: true
表1关键参数说明
| 参数             | 参数类型   | 描述        |
| containername  | String | 容器名称。        |
| name           | String | volume的名称。        |
| mountpath      | String | 挂载路径        |
| extendpathmode | String | 将在已创建的"卷目录/子目录"中增加一个三级目录，便于更方便获取单个Pod输出的文件。 支持如下五种类型，详情请参考[容器日志](https://support.huaweicloud.com/usermanual-cce/cce_10_0110.html)。 - None：不配置拓展路径。  - PodUID：Pod的ID。  - PodName：Pod的名称。  - PodUID/ContainerName：Pod的ID/容器名称。  - PodName/ContainerName：Pod名称/容器名称。   |
