# AI防护者安装
1. 登录华为云管理控制台
2. 创建弹性云服务器（ECS），选择镜像版本为centos7，数量为3
   图1AI防护者安装1
   ![](https://support.huaweicloud.com/aidefender-sag/zh-cn_image_0000001672910981.png)
3. 登录ECS，上传AI防护者安装包
   [root@ecs-336a ~]# ls
   zyWAF-develop-9.0.3-942.centos7.x86_64.rpm
   zyWAF-GM-stable-develop-9.1.0-9.1.0-810.centos7.x86_64.rpm
4. 安装AI防护者计算节点
   进入安装包所在目录rpm -ivh / "安装包名称"
   [root@ecs-336a ~]# rpm -ivh ./zyWAF-develop-9.0.3-942.centos7.x86_64.rpm
   Preparing...                          ################################# [100%]
   Updating / installing...
   1:zyWAF-9.0.3-942.centos7          ################################# [100%]
   ---------- Creating the MariaDB system databases and tables
   ---------- Starting the server..Done
   ---------- Creating/updating users
   ---------- Stopping the server.Done
   ---------- Creating zyWAF databases
   ***** Starting upgrade at Fri Jul 28 10:31:31 2023
   ----- Info: Skipping bin/cvt-settings -f "/usr/local/waf/etc/my.cnf"
   ----- Info: Skipping conversion of logs/alerts.db
   ----- Info: Skipping conversion of logs/audit.db
   ***** Finishing upgrade at Fri Jul 28 10:31:31 2023
5. 安装AI防护者管理节点
   [root@ecs-336a ~]# rpm -ivh zyWAF-GM-stable-develop-9.1.0-9.1.0-810.centos7.x86_64.rpm
   1:zyWAF-GM-9.1.0-810.centos7       ################################# [100%]
6. 启动管理节点、计算节点
   [root@ecs-336a ~]# systemctl start zywaf
   [root@ecs-336a ~]# systemctl start zygm
   [root@ecs-336a ~]# systemctl status zygm
   ● zygm.service - zyProtect Web Application Firewall Global Manager
   Loaded: loaded (/usr/lib/systemd/system/zygm.service; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2023-07-28 10:36:20 CST; 1min 49s ago
   Docs: https://www.zyprotect.com/zywaf-en/
   Process: 29465 ExecStartPost=/usr/bin/sleep 0.2 (code=exited, status=0/SUCCESS)
   Process: 29463 ExecStart=/usr/local/waf-gm/bin/zygm $OPTIONS (code=exited, status=0/SUCCESS)
   Main PID: 29464 (zygm)
   Tasks: 1
   Memory: 74.1M
   CGroup: /system.slice/zygm.service
   └─29464 /usr/local/waf-gm/bin/zygm
   Jul 28 10:36:19 ecs-336a systemd[1]: Starting zyProtect Web Application Firewall Global Manager...
   Jul 28 10:36:20 ecs-336a systemd[1]: Started zyProtect Web Application Firewall Global Manager.
   [root@ecs-336a ~]# systemctl status zywaf
   ● zywaf.service - zyProtect Web Application Firewall
   Loaded: loaded (/usr/lib/systemd/system/zywaf.service; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2023-07-28 10:31:31 CST; 6min ago
   Main PID: 28101 (wafmanager)
   Tasks: 16
   Memory: 94.5M
   CGroup: /system.slice/zywaf.service
   ├─28101 /usr/local/waf/bin/wafmanager
   └─28118 /usr/local/waf/bin/waf --no-daemon --no-rastate --no-crawl -path /usr/local/waf
   Jul 28 10:31:31 ecs-336a systemd[1]: Starting zyProtect Web Application Firewall...
   Jul 28 10:31:31 ecs-336a systemd[1]: Started zyProtect Web Application Firewall.
